AutoCAD 2013/2014/2015
Member
yamataj
Message 1 of 3 (204 Views)
Cannot format text - ribbon disabled
204 Views, 2 Replies
01-31-2013 01:10 AM
Hi
I got a large numeber of drawings where text is almost uneditable - probably because it is made in an earlier AutoCAd version. I can double click and replace text but not edit/format it - the whole ribbon is inaaccessible (an "access denied sign shows when I hover/click over ribbon area". If I copy and paste the text, it is suddenly possible to edit, format and do whatever I want. trouble is that there is A LOT of text and it would take ages to do it manually.
The text is displayed wrongly, as show on the attached figure. I want to be able to use nordic letters å,ø,æ and be able to change size, font and so. On the attached figure "Måler" is displayed as "Moler". Is there a way to convert all the text so it is formatable?
Thanks in advance
*Expert Elite*
braudpat
Message 2 of 3 (201 Views)
Re: Cannot format text - ribbon disabled
01-31-2013 01:23 AM in reply to: yamataj
Hello
When you select ONE of this strange Text, are they : Text or MText ou Attribute ?
Bye, Patrice
Bye, Pat
Member
yamataj
Message 3 of 3 (194 Views)
01-31-2013 02:08 AM in reply to: braudpat
Where can I see it?.
I am not sure if it helps but It says DDEDIT down in the command window when I select text I want to format.
I have, however, found a partial solution:
- Select all text fields
- Right click propreties
- Scroll down to text
- Change style from what it says (mine says ISO) to something else. ÅØÆ are now displayed correctly.
- One can also change height in the same window
But as to why my ribbon gets disabled or why text editor is not showing I still have no clue. :/
I hope you have an answer for that.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
