AutoCAD 2013/2014/2015
CAD105
Message 1 of 8 (1,091 Views)
Can't open saved DWG drawing
1091 Views, 7 Replies
02-22-2013 11:26 AM
I'm in AutoCAD 2013. I've been working on a drawing everyday (was just working on it yesterday), but can't open it now. I just get a blank gray screen when I open if from within AutoCAD. When I open it from my computer drive while AutoCAD is closed, AutoCAD opens and I get "Drawing1.dwg." I've tried the RECOVER command, but I don't get a response. I tried RECOVERALL command which let me choose a file to recover, but it responded saying it could not recover the drawing. Can anyone help me find this drawing? Thanks.
*Expert Elite*
Patchy
Message 2 of 8 (1,069 Views)
Re: Can't open saved DWG drawing
02-22-2013 11:59 AM in reply to: CAD105
Rename .bak to .dwg and try open that one.
CAD105
Message 3 of 8 (1,064 Views)
02-22-2013 12:06 PM in reply to: Patchy
That worked! Thanks so much!
New Member
cwilber
Message 4 of 8 (887 Views)
05-21-2013 08:09 AM in reply to: CAD105
same thing happening to me! I just installed 2014 and after i save a drawing i can't open it.
changing the bak to dwg did nothing... anyone know what is happening? Thanks!
Member
ann.vandenborre
Message 5 of 8 (664 Views)
10-22-2013 12:36 AM in reply to: CAD105
Hi all,
We have the same problem on several pc's. Renaming the .bak to .dwg solved the problem. But as CAD manager the main question remains 'Why is this happening'? How can I solve this issue permanently?
Thx,
*Expert Elite*
JGerth
Message 6 of 8 (652 Views)
10-22-2013 06:48 AM in reply to: ann.vandenborre
the 'why' will take some investigation.  Start with the operators -- any error messages on save?  autosave on or off? isavepercent is set to what?  Cimmuncation center running or diabled?  360 synching? content server/explorer running?
Continue investigating with the Windows Event viewer logs.  Anything showing there?  Is auditing enabled?
File local, or on a server?  server running windows OS or somehting else?  is a NAS involved?
Member
ann.vandenborre
Message 7 of 8 (605 Views)
11-05-2013 02:43 AM in reply to: ann.vandenborre
Thanks for the response.
We have had this problem several times in the last 3 weeks.
The problem could be server related as the back-up on these files and even folders went wrong too.
(no usable back-up)
IT is checking it out.
ir-arch. Ann Van den Borre
CAD manager
VK HEALTHCARE | BUILDINGS | INDUSTRY | INFRA
Value by design
VK GROUP Brugsesteenweg 210, 8800 Roeselare, Belgium
t +32 51 26 20 38 f +32 51 26 20 37 m +32 473 91 94 36 e ann.vdb@vkgroup.be w www.vkgroup.be
SAVE THE DATE: VK-SEMINAR FIRE SAFETY ENGINEERING IN HEALTHCARE December 5th 2013
****DISCLAIMER****
This communication is confidential and for the sole useof the addressee. If you are not the intended recipient,
please immediately notify the sender by e-mail at the address shown and then delete it from your system
without copying, disclosing or forwarding its contents. Thank you.
New Member
jypeejypee
Message 8 of 8 (165 Views)
05-20-2014 11:38 PM in reply to: ann.vandenborre
1.) change .bak to .dwg
2.) open the file ( it opens as blank file)
2.) click the drawing utilities tab then recover then search for the file
hope it works :smileyhappy: GODbless you
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
