I would like to know whether can i stop the function of going to layout model mode, after making amendment to the blocks,
I prefer it to stay at model mode after making amendment.
Hi There,
Welcome to Autodesk Community,
Do you mean that you want to stay in Model Space after you have created a block? There is a tick box in your create box dialog box "Open in block editor" that you need to deselect. Please see attachment
If this is not what you are looking for, could you please clarify what you are talking about?
I had tried your method and it didn't work. What i mean is after i edit block definition,
there after go into block editior, after i had amended save the block editor, i can't
stay at model mode to continue my drawings, the program will straight away go
to layout mode instead. Refer to attachment...
I just tried it in both Acad C3D 2012 and Acad 2014 (I don't have 2013). I was unable to reproduce the issue. And in fact if I am in a layout before starting the block editor, then when I close the block editor, I see the model space flash just before it displays the layout. But if I was in model space before starting the block editor, it goes back to model space upon exiting the block editor.
Don Ireland
Engineering Design Technician
In your first screenshot, the command line reads "Regenerating model", but there is no indication of the BEDIT command, which leads me to believe that something in the way you are executing BEDIT is "switching" to the Model tab (even if you're already there). It may be that this "method" (whatever it is) is switching you to a Layout tab. In the third screenshot you can see "Regenerating layout" followed by "Regenerating model", so something "special" or "custom" seems to be running.
How are you executing BEDIT? Are you typing in "BEDIT", picking it from an interface element (toolbar, menu, ribbon, etc.), or other?
To be sure you are running the "native" command, type ._BEDIT (starts with dot and the underscore character) and let us know if the behavior is still the same.
If so, please post a screenshot or copy/paste what you see on command line (use F2 key) during and after the "native" command.
