ACAD 2014
I normally turn off the Batch Plot (Save As List) feature cause I never use it, however recently I turned it on and saved my choice.
How do I turn it off again? Is there a variable for this one?
Thx
Solved by Shawn_Niles. Go to Solution.
I'm not sure of the exact feature you are speaking of. However, it sounds like you may have supressed the message box that normally comes up. Please try this:
1) Type in OP at your command line.
2) Go to the System tab.
3) Click on Hidden Messages Settings.
Do you see in the list the feature that you would like to be prompted on again? If so, then you can uncheck it here to bring it back.
If this is not what you are looking for, could you be a little more descriptive in terms of what command you are using, what is happening, and what you would like to happen?
Thanks. That did the trick.
Not sure which one of them was the right one, as there were severaql for plotting and printing, so I checked them all.
