Other than writing a script file, is there a way to batch Export a directory of DWG files to Microstation DGN? I thought AutoCAD Trueview did that…but looking at documentation….doesnt appear to be the case.
Hy
way a a third party converter ??? i see no reason for ? ACAD 2013 LT did it .
the only thing you need will be a windows script or simuler that collect all the files and made a *.scr file for you , you start the run and make a coffee break
cu cw
Point for you , i missd that part
but what are the reasion for / or the problem not to use a script ? its free and no athier software in use ?
cu cw
Hey CW,
I know it is a bit old post, but...
New to scripting. Do you mind share your knowledge - how the script would look like. I have more than 300 files to convert from dwg to dgn and doing it manually would be painful. 🙂
Milos
