AutoCAD 2013/2014/2015
Active Member
Message 1 of 5 (968 Views)
BUG: Relative coordinates are not working in UCS Origin
968 Views, 4 Replies
09-17-2012 08:00 AM
I noticed that relative coordinates are not working in UCS Origin in Autocad 2013.
I used to create an UCS according to a mesh of coordinates (North/East). To do that I first aligned the UCS to the North axis and point the origin to known coordinates (this part is working). Then I created a new UCS using relative coordinates, like "non @ -286200,-7485500". This relative coordinates entry are not working anymore in this version of Autocad (2013). Does anybody also notice this bug?
Alfred.NESWADBA
Message 2 of 5 (954 Views)
Re: BUG: Relative coordinates are not working in UCS Origin
09-17-2012 01:02 PM in reply to: Osasco
But???
What are you getting as result? At least let us know what AutoCAD is talking to you when you tried that. In other words, copy the content of the command-window so we can see what you did exactly and what AutoCAD sent to you as message, what it does not like.
- alfred -
Alfred NESWADBA
Active Member
Message 3 of 5 (950 Views)
09-17-2012 01:39 PM in reply to: Alfred.NESWADBA
Sorry for not being clear. Autocad accepts the relative coordinates but the values are not right.
Below is an example: I started a new drawing, created a line in 0,0 to 5,0; then moved ucs using relative coordinate (non @-10,-10) and en check coordinates of the line. It should be 10,10 but it it  81.2696,93.5429.
Command: l LINE
Specify first point: 0,0
Specify next point or [Undo]: non @5,0
Command: ucs
Current ucs name:  *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: o
Specify new origin point <0,0,0>: non @-10,-10
Command: ID Specify point:  X = 81.2696     Y = 93.5429     Z = 0.0000
What I realized now is that when Autocad prompts to coordinates entry it first points the reference coordinate to the UCS icon on the screen (!)
Now I found out the solution: I have to change UCS icon property "Selectable" to NO...
But don't you think this is a BUG!?
Osasco
Alfred.NESWADBA
Message 4 of 5 (946 Views)
09-17-2012 01:55 PM in reply to: Osasco
If you mean with 10,10 the startpoint of the line, then you are right.
For me: I can't reproduce this issue, see my command-output:
Command: _line
Specify next point or [Undo]: @5,0
Command: _ucs
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: _origin
>>Enter new value for ORTHOMODE <0>:
Resuming UCS command.
Specify new origin point <0,0,0>: _none @-10,-10
Command: _id Specify point: _end of  X = 10.0000     Y = 10.0000     Z = 0.0000
- alfred -
Alfred NESWADBA
Active Member
Message 5 of 5 (942 Views)
09-17-2012 02:19 PM in reply to: Osasco
Check if UCS icon property "Selectable" is YES or NO. If it is NO, set it to YES and try again.
With UCS icon property "Selectable" set to YES, I realized that when Autocad prompts to coordinates entry it first points the reference coordinate to the UCS icon on the screen (!)
With UCS icon property "Selectable" set to NO, there is no error.
Don't you think this is a BUG?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
