Dear all
I am using autocad 2013 and I face a serious problem
when I was working in file sudden it hang and say automation error file is busy
after close file and reopen again I found nothing in file
and size of file become small
and backup file have nothing also
can anybody help me
and give his advice to me
Discussion_Admin
This thread about a week ago, sounds like your situation.
Please tell me what is the solution
I go to link and I found no solution
thanks for your help
at the moment it looks like nobody has found a solution yet, but it might be very helpful to know what you have installed like servicepack, apps, tools, operating system, antivirus-software, .... so you and the other one having that problem might see what is equal to you both ==> having that found might be then answer the question for the solution.
Without any new information I guess it's not possible to identify what makes 3 workstations in the world having that special issue. Just asking "what is the solution" does not bring you any step closer to the origin of the problem. 😉
- alfred -
Well, if they all were running 2013... suggested solution is to get 2014. (and quick... because this is about the scariest bug I've ever heard of)
I doubt the problem is with AutoCAD 2013. 99.99% of 2013 users are not having this problem. It's almost certainly related to a buggy 3rd party app/macro.
The other post is reporting the problem is present only on a laptop when they are out of the office.
Is that your issue too?
Are you running a 3rd party add-on? Are you running an app from the Exchange Apps? "Automation Error" is usually (but not always) a code error in VBA or Visual C++.
Did this problem just start? 2013 is not new, so something on your end is new, what is it? new PC? New OS? New PC?
Did it start when you installed 2013? You provide so little information and continue to provide so little information it's hard to tell what's going on.
Dear All,
I found the solution to the problem.
our more than 50 Engineers were facing this problem and we had to do following to fix the issue:
Problem solved.
Thank You
Regards
Abdul Wajid
Dear Sir
I have found very simple solution for the automation issue however it is required to have another PC without the same this error
i have tried that on my PC and it is working fine however make sure that the support folder which you copy it is from a PC with no old records for this issue
Regards
Faisal AG
