I've installed the latest version of Autocad 2014, and when I lunched the program, I was asked to update the driver of my VGA as this message below.
However, when I went to the home page of my Acer, then searched for all drivers/latest for Windows 7(64bit), I didn't find any drivers for graphics card at all.
Besides, when I installed the 2013 version of AutoCAD, I didn't face any errors updating graphics card.
Solved by olivier.eckmann. Go to Solution.
Thanks a lot,
Yes, I got that my Graphics card is not supported to open 2014 version of Autodesk, and appreciate your time, but I really have tried installing the Autodesk on a very latest HP laptop, with these specs,
I really don't want to open antoher thread for the errors with the screen shots mentioned in my post posted 02-14-2014 05:54 PM, because I am expecting this thread is being discussed the same issue.
So could you kindly reply to me to close this issue?
Could anyone please at this splendid forum take some of his precious time out to reply to my post posted in 02-14-2014 05:54 PM, because I am expecting this thread is being discussed the same issue?
Thanks a lot for your reply.
NOTE: the erros below are for installing the pageg of Autodesk AutoCAD which comes along with Autodesk Recap.(Autodesc Recap was installed, however, the Atudesk AutoCAD wasn't installed.
I really had to post again my post, because it sound as though there is missunderstanding.
NOTE: these erroses below installing AutoCAD are also shown me while installing AutoCAD on a very latest laptop with these specs:
Intel CORE i 5, 2.65GHz)
RAM 6GB
H.D.D: 600GB
Intel Graphics Card HD with very high RAM.
ATI Radeon Craphics card
If the errors were related to that Windows 7 must be SP3, I would be saying that I have never ever heard that Windows 7 can be SP2 nor SP3.
I installed the AutoCAD 2014, but once I clicked on 'install' button, I faced the error below, I was given two options 'retry' and 'cancel'. I click on 'cancel'.
Then, I have faced these three errors in order, in each time, I clicked on 'OK' until the fourth screenshot, in which I have chosen 'trial version'.
After clicking on 'next' on the error above, I reach to screen shot below in which is AutoDesk Recap is checked, however, AutoCAD cannot be accessible.
I have clicked on System Requirments, and I foud these:
http://docs.autodesk.com/ACD/2014/ENU/System%20Requirements/index.html
NOTE: My laptop's specs are:
Intel Celeron Processor 530(1.73Ghz)
RAM: 2.5GB
H.D.D with a free 60GB space of out of 80GB
Mobile intel Graphics Media Accelerator X3100
System: Windows 7 ultimate(64Bit) SP1.
.NET Framework Version 4.0.
Then, why was Autodesk AutoCAD not installed with Autodesk Recap? Only Autodesk Recap was installed.
Thanks a lot,
I really concluded from your reply that you bothered yourself to reply to me. I am not trying to exhaust you or others.
However, the that installing Autodesk which includes(AutoCAD and Repcap) didn't succeed in installing AutoCAD, however, it succeeded in installing Recap. I have tried installing Autodesk 2014 on two laptops(Dell, and HP), both of them have good specs, but only the Repcap was installed. However, AutoCAD wasn't installed, and those errors showing while installing AutoDesk show you that there was a partial insallation for Autodesk. which resulted in AutoCAD was not installed, however, Recap was isntalled.
Thus, I don't need to exhaust you nor reseller.
Hello, I have the latest iMac with Intel 2.9 GHZ QuadCore i5, memory 8 GB 1600 Mhz DDR3, with Graphic NVIDIA Geforce GT 650M 512 Mb.
I install Windows 8 with parallels, everything works fantastic, even Inventor professional, AutoCad 2014 etc, I found ridiculous that Recap is asking me for a GL 3.1 graphic card, I have the latest update on this NVIDIA graphic card, just about any Autodesk software opens without any lack of graphic performance on Windows 8, I search for such thing and tried to install it on the Windows 8.1, I even went to the NVIDIA website, I download the graphic card that belongs to my graphic card for Windows 8, it said that I have the latest graphic card update.
Recap will not open because it said that I have the 1.1 version, where should I get this software at???
Thank you
Vincent
Parallels has the limitation of only providing Support up to OpenGL 2.1 http://kb.parallels.com/en/115487
@thomas.schwaiger wrote:Parallels has the limitation of only providing Support up to OpenGL 2.1 http://kb.parallels.com/en/115487
Thanks a lot,
Could you be a little bit more detail about 'Parallels has .....'? What you meant? Did you answer my concern in question in my very first post, or you're talking about something else?
