I recently downloaded AutoCAD 2014 (for the nth time) trying to get the free software for students, college, similar to the one used in class, for my PC. After each download, a window containing these words pops up, "The drawing file being opened was not created by a product from an Autodesk Education Suite". Is there a link that I can download AutoCAD 2014 for school (college) that won't always have that pop up every time I try to use it? What does Autodesk Education Suite mean? Please, please help.
Solved by JDMather. Go to Solution.
@gmusembi wrote:
... "The drawing file being opened was not created by a product from an Autodesk Education Suite"....
Why is this a problem for you?
All it means is the default template was created using a the commercial license rather than student license.
Simply a reminder that any work you create with this student license of for learning purposes only - not for commercial use.
Your instructor should have been able to explain this to you.
Make sure you install Service Pack 1. (search google on AutoCAD 2014 Service Pack 1 to find the download.
