Hi eveyone,
I'd like to know if there is a way to vectorize an image from autocad. In a near future, I'll be asked to render maps with parks, main streets, lots, etc. And I'd like to know if autocad was able to "auto-trace" an image, i.e from google map and trace it approximatly instead of doing it manually.
I don't know if some of you would be able to answer me if GIS software are better when it comes up to play with maps, or if they have such vectorize system. I'm kind of a novice when it comes to GIS software.
Plus, maybe some of you would know where I could actually extract specific datas like streets, loots, zones, etc. or find similar database. I don't think google map offering a good redering with satelite and I don't like the way google render the streets, and it doesn't give us some informations like the zones, etc.
Don't know if anyone could help me with these interrogations,
thanks a lot for your help!
Which country are these maps of? You may be able to find some simplier line-only maps online from a GIS depositary or government department.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
GIS products definitely sound like what you are looking for. Just be mindful of intellectual property rights - you can end up dealing with industry heavyweights who are sensitive to others using their imagery without correct licensing arrangements, with legal departments to match.
Canada does have a good set of data and maps you can use, however you need to use a GIS program like Autocad Map3D to get the most use of the data. To vectorize you would use Raster Design.
Darawork
AutoDesk User
Darawork
AutoDesk User
Darawork
AutoDesk User
Darawork
AutoDesk User
