I whant to load my plugin on autcad startup and this is the PackageContents.xml
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage SchemaVersion="1.0"
AutodeskProduct="AutoCAD" Name="AutoCADMyPlugin"
Description="AutoCADMyPlugin" Version="1.0.0" Version="1.0.0"
ProductType="Application" SupportedLocales="Enu" AppNameSpace="AutoCADMyPlugin" Author="Autodesk, Inc."
ProductCode="{B2D833E7-8E89-45FF-9281-B8CE38F3BF8C}" UpgradeCode="{34060BF2-49ED-46A2-BF6E-4C7B1772B397}"
OnlineDocumentation="www.autodesk.com">
<CompanyDetails Name="Autodesk, Inc." Url="www.autodesk.com" Email="info@autodesk.com" />
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD*" SeriesMin="R19.1" SeriesMax="R20.0" />
<Components>
<ComponentEntry
AppName="AutoCADMyPlugin"
ModuleName=".\Contents\AutoCADMyPlugin.dll"
AppDescription="AutoCAD 2015 my Plugin"
LoadOnAutoCADStartup="True" >
</ComponentEntry>
Dll works fine when I use NETLOAD command, my ribbon menus appears, but on autocad sturtup it doesn't work...
-->Shouldn't this use forward slashes instead of backslashes, e.g. "./Contents/AutoCADMyPlugin.dll" ??
Hope that helps!
Greg
