Hello, We have recently started using AutoCAD 2015 at the office, and so far so good, but when i´ve tried to render a 3D model wich contains .IES files atached to lights the render window as well as the Autocad Window crashes whitout any warnings or error messages. I´ve also noticed that although AutoCAD closes completly, the AutoCAD.exe process is still running. I´ve tried to render this and other similar models in the same and others computers at the office with different hardware cofigurations and always get the same result!. I´ve also tried at home, and the problem is the same.
Is there anyone having the same problem? Have we made any mistakes installing the software at the office?. same models would render fine on 2013 or 2014.
Any help would be apreciated.
Thanks!!!
Jose Suarez
AutoCAD 2012 Certified Professional
Revit Architecture 2014 Certified Professional
welcome @forums.autodesk.com!
Can you upload a drawing that you can't render successfully?
As rendering has so many different options and settings it's in most cases useful to have a drawing to compare the settings and see what's different.
- alfred -
