AutoCAD Forum
Autocad 2015-Where can i put in custom scales for viewport?
24 REPLIES 24
Message 1 of 25
UNCWPM
17866 Views, 24 Replies
You used to be able to type in whatever scale you wanted in the Viewports toolbar.  Looks like they have done away with this option.  Does anyone know where I can type in custom sizes now?  Where did this ability move to or how do I get it back?
Thank!
Tags (2)
24 REPLIES 24
Message 2 of 25
Alfred.NESWADBA
in reply to: UNCWPM
Property window is one option, but when you turn on the toolbar "VIEWPORTS" also with 2015 (using command _-TOOLBAR) to type it in the custom scale like the old way was.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 25
UNCWPM
in reply to: Alfred.NESWADBA
Thanks Alfred.  I'll look at Properties.
They actually took off the 'dropdown menu' where you could select a scale or type in a scale on the Viewpots toolbar.  Not sure what the point in getting rid of it was...only took up a 1/2" of screen space.  Ha ha
Message 4 of 25
GrantsPirate
in reply to: UNCWPM
I have the Viewport toolbar showing on my setup and I can type in there like always.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 25
UNCWPM
in reply to: UNCWPM
Not sure why mine is shrunk.  I only have the 4 icons with no drop down box.
Message 6 of 25
Alfred.NESWADBA
in reply to: UNCWPM
you have to undock it or dock it to the top or the botton.
If you dock it on the left or the right side the popup-lists (combobox) are disabled).
- alfred -
Alfred NESWADBA
Message 7 of 25
UNCWPM
in reply to: UNCWPM
Here is what it looks like on my screen.
Message 8 of 25
Alfred.NESWADBA
in reply to: UNCWPM
have you migrated menus from older releases or are you using a vertical product like ACA or Mech or so?
Mine looks like that:
- alfred -
Alfred NESWADBA
Message 9 of 25
GrantsPirate
in reply to: UNCWPM
Check your CUI and modify the toolbar if needed.
GrantsPirate
EXPERT ELITE MEMBER
Message 10 of 25
UNCWPM
in reply to: UNCWPM
OK I think I will try this CUI method.
I just installed plain old AutoCAD 2015 from our subcription site. I didn't migrate anything, butI do have a ton of Autodesk products installed on my computer so maybe they are somehow affecting each other.
Message 11 of 25
GrantsPirate
in reply to: UNCWPM
Forgot to highlight one other important choice in the CUI, see attached.
GrantsPirate
EXPERT ELITE MEMBER
Message 12 of 25
UNCWPM
in reply to: GrantsPirate
Thanks I got everything back the way I like it.
Message 13 of 25
Peterga
And if i need to add a scale, for example 1:75 or 1:2500, or reset the list like older versions? it' incredible we are going backwards
Message 14 of 25
Alfred.NESWADBA
in reply to: Peterga
Then start command _SCALELISTEDIT and create your scale(s).
Then start command _OPTIONS ==> tab "User Preferences" ==> button "Default Scale List" ... and put in that scales you want to have as default whenever you reset the scalelist in a drawing.
Nothing backwards, same as 2014, 2013, ...
Or have I missed something?
- alfred -
Alfred NESWADBA
Message 15 of 25
cad-pe
in reply to: UNCWPM
Firstly to add a new scale to the viewport toolbar use: SCALELISTEDIT
Secondly, you need to have a viewport active.
Message 16 of 25
Peterga
it's not the same, in olders version with a simple clic in the scale list I could modify or add scales, obviosly with the command scalelist i can, but it's not the same exactly. Sin-título-1.jpg
Message 17 of 25
Alfred.NESWADBA
I don't see the difference?
- alfred -
Alfred NESWADBA
Message 18 of 25
Peterga
Oh, no in my autocad don't open this menu: Sin-título-1.jpg
Message 19 of 25
Alfred.NESWADBA
try that in a new drawing (based in an orignal AutoCAD template), I guess your list of scales is to long, isn't it?
- alfred -
Alfred NESWADBA
Message 20 of 25
Alfred.NESWADBA
I have tried to reproduce the big amount of scales, in that case let the list pop up, move the mouse over the list and use the mouse-wheel to scroll down, that's it.
- alfred -
Alfred NESWADBA
”Boost
