AutoCAD Forum
Autocad 2014 crashes when in 3d modeling
6 REPLIES 6
sampsont
345 Views, 6 Replies
I have a Dell Latitude E6250 running Windows 7 Pro, Intel Core i7 -2760QM @ 2.4GHz, 2401 MHz, 4 core processor. Running 64 bit with 8GBs of memory.
Now that you have the specs for my machine, here's the issue. I'm trying to 3D a stage drawing. I've done this before but not to this scale. The overall file size is 19MB. I've read that the system I have does meet(?) the min. requirements. The screen goes white and says the system has a problem than shuts down the autocad program. Any thoughts? Normally I don't do a full 3d rendering of the entire set but I need to answer a question that can be answered with a 3D model.
6 REPLIES 6
braudpat
in reply to: sampsont
Hello
Welcome to the Autodesk/AutoCAD Forums !
With 3D medium models, 8 Gb is not enough !
But a few other ideas :
1) Please open your DWG in RECOVER Mode
2) PURGE + PURGE ...
3) Go back to Model Space if necessary
4) CANNOSCALE = 1:1
5) SCALELISTEDIT and erase all posible Scales except the "famous" 1:1
6) ReSave the DWG ...
7) Have you installed the SP1 for ACAD 2014 ?
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2014-service-...
😎 Which graphic card ?
If ATI or NVidia, have you installed the latest driver ?
Reboot ...
Now close all unnecessary Windows Application ... Kill all unnecessary Windows Tasks ... ONLY ACAD.exe will run ...
Relaunch ACAD ... ReTest ...
Waiting ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
JDMather
@Anonymous.sampson wrote:
 The overall file size is 19MB....
Are you using xrefs?
dgorsman
in reply to: JDMather
Same question but with blocks.  Between XREFs and blocks its possible to greatly reduce the size of a model.
sampsont
in reply to: braudpat
Normally, I don't 3D an entire set but this time I'd thought I would. Clearly 8Gb isn't enough, but this computer max is 8Gb.
Running with Windows 7, with SP1 and all updates. I have NVidia and driver is up to date.
I usually disable all extra features and programs, including wifi.
Usually I only use blocks when I'm using the same object multiple times. I have 30 completely different objects, I can easily block them all.
And I have no XRef. in the file. And yes the file is almost 20MB.
I will try all your posted suggestions.
If it can't be done, it's not a huge deal, just means I get a computer with a bit more power.
sampsont
No I'm not running any XRef. in file.
sampsont
in reply to: dgorsman
Will try suggestions. Thanks.
”Boost
