Hi,..
I Downloded autocad 2014 from autodesk and tried to install in my computer with windows 8.1 64 bit, but I got "Base_T-1.cab" file corrupted or could not Accessed,.
So I downloaded the same 1.47 gb form autodesk but again I got the same problem, I thought the problem might be because of Windows 8.1, so I tried to install in in another computer having windows 7 64 bit, but same result only I got,.
I browsed in internet and people said some solutions but nothing is worked,.
I found that .cab file and I checked it with Winrar, same error I got, so this is not because of OS,...
And there is no .cab file repair tool for "freeware"
Please help me to get out of this issue,.
I am not a outstanding person about computer tricks,.
Please explain me in detail,.
Thanks in advance,.
You might also try posting this in the Installation and Licensing forum.
Are both downloads exactly the same?
Is it possible that you _executed_ the files from the original download after downloading it again?
If Autodesk has posted a bad file, then everyone who downloads it would have the same problem.
I tried to download and install it today and got the same issue... I hit the cancel button, then retry download, but then shortly after it prompted me to a "installation finished" screen...though it failed to install all of the components
