AutoCAD Forum
Autocad 2014 corrupted file error Base_T~1.cab
2 REPLIES 2
4201 Views, 2 Replies
Hi,..
I Downloded autocad 2014 from autodesk and tried to install in my computer with windows 8.1 64 bit, but I got "Base_T-1.cab" file corrupted or could not Accessed,.
So I downloaded the same 1.47 gb form autodesk but again I got the same problem, I thought the problem might be because of Windows 8.1, so I tried to install in in another computer having windows 7 64 bit, but same result only I got,.
I browsed in internet and people said some solutions but nothing is worked,.
I found that .cab file and I checked it with Winrar, same error I got, so this is not because of OS,...
And there is no .cab file repair tool for "freeware"
Please help me to get out of this issue,.
I am not a outstanding person about computer tricks,.
Please explain me in detail,.
Thanks in advance,.
2 REPLIES 2
rkmcswain
You might also try posting this in the Installation and Licensing forum.
Are both downloads exactly the same?
Is it possible that you _executed_ the files from the original download after downloading it again?
If Autodesk has posted a bad file, then everyone who downloads it would have the same problem.
R.K. McSwain     | CADpanacea | on twitter
I tried to download and install it today and got the same issue... I hit the cancel button, then retry download, but then shortly after it prompted me to a "installation finished" screen...though it failed to install all of the components
”Boost
