AutoCAD Forum
Autocad 2014 and Autocad 2007 format
2 REPLIES 2
fedemonte89
873 Views, 2 Replies
since I have Windows 8.1 I try to use Autocad 2014, that has native support, but when I save in Autocad 2007 format I receive a message like that in the image below.
Where I could find information about retrocompatibility of Autocad 2014? There some known issues in saving Autocad 2014 in previuos format like 2011 o or 2007 format?
What about object enablers?
Thank you for your help.
Federico
2 REPLIES 2
>>>click<<<
Yes, all objects that are new AutoCAD releases may be not displayed correctly in older AutoCAD's. Most of the objects are converted to be at least visible/plotable in older AutoCAD's, but you should not do any modifications to that.
You can try command -EXPORTTOAUTOCAD, choose the format you like to save your drawing back (e.g. DWG2007) and let AutoCAD convert those objects down.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
fedemonte89
in reply to: fedemonte89
Thank you so much! I will try it!
”Boost
