AutoCAD 2013/2014/2015
Distinguished Contributor
Message 1 of 10 (449 Views)
Autocad 2013
449 Views, 9 Replies
09-24-2012 11:48 PM
Hello Guys,
Is there anyway i need to configure or set just to see in my command prompt what im TYPING (letter/text). Beside press F12. please see attached.
Thank you in advance.
rkmcswain
Message 2 of 10 (411 Views)
Re: Autocad 2013
09-25-2012 05:43 AM in reply to: ennujozlagam
So when you type, nothing shows up in the command line?
Make sure DYNMODE = 0 and NOMUTT = 0
Member
tatakpinoy
Message 3 of 10 (364 Views)
Re: Autocad 2013
09-25-2012 07:58 PM in reply to: rkmcswain
Thank you for your prompt reply. I tried and follow your instructions but still the same.
What im trying to say that for example when i created new layer and make, i cannot see what im typing for the new layer.
Please see attached.
Patchy
Message 4 of 10 (350 Views)
Re: Autocad 2013
09-25-2012 09:55 PM in reply to: ennujozlagam
Type in dot Layer
.LAYER
See if you will have the Layer Pallette back.
Member
tatakpinoy
Message 5 of 10 (342 Views)
Re: Autocad 2013
09-25-2012 10:46 PM in reply to: Patchy
Hi, thank you for your reply.
I think you didnt understand what im trying to say here.
it is not the layer that i cannot see (most of the command). what i meant is that when i type any command in the command prompt i cannot see the letters im typing.
Thank you.
Patchy
Message 6 of 10 (272 Views)
Re: Autocad 2013
09-26-2012 06:22 AM in reply to: tatakpinoy
Go to OPTIONS and change the background color, your text and background is of the same color.
Member
tatakpinoy
Message 7 of 10 (222 Views)
Re: Autocad 2013
09-26-2012 05:44 PM in reply to: Patchy
Hi Patchy,
i think you still dont understand what im trying to explain here. i know how to configure in OPTIONS.
My problem is that when i created new layer when i type "layer-make" then i need to type the new layer (for ex. steel)
the problem is that i didnt see layer "steel" in the command prompt. Ypu will only see the layer "steel" when you press enter.
Anyway thank you for your help. Please see attached
Patchy
Message 8 of 10 (209 Views)
Re: Autocad 2013
09-26-2012 07:26 PM in reply to: ennujozlagam
Something is not right with your autocad, if you type in LA as shown in your photo, the dialog box for Layers ought to show up.
Only time it shown as your photo is when you type in -LA
Reinstall your autocad.
rkmcswain
Message 9 of 10 (178 Views)
Re: Autocad 2013
09-27-2012 06:18 AM in reply to: tatakpinoy
As a test, type in ._-layer (note the leading period, underscore, and hyphen) - INSTEAD OF just "la".
Do you get any different results?
rkmcswain
Message 10 of 10 (176 Views)
Re: Autocad 2013
09-27-2012 06:20 AM in reply to: Patchy
A reinstall is a bit extreme and won't necessarily help if the "la" command has been overridded with a lisp or other external command. Let's see how ._-layer reacts for the OP.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
