AutoCAD 2013/2014/2015
Member
yves.menard
Message 1 of 15 (7,189 Views)
Autocad 2013 Drawing preview image not seen in Open File Dialog Window
7189 Views, 14 Replies
06-01-2012 06:17 AM
I use Autocad since version 2.0 and it's the firs time that I don,t find an answer for a problem.
My THUMBSAVE value is 1.
Still not showing a preview of the dwg.
Product Support
Laurent.Pallares
Message 2 of 15 (7,152 Views)
Re: Autocad 2013 Drawing preview image not seen in Open File Dialog Window
06-04-2012 03:46 AM in reply to: yves.menard
Did you open it with the 2013 Version, or it was opened with the 2012, or earlier.
This usually happen trying to preview earlier release files.
The file has to be opened before, so it can generate a preview later one.
Best Regards
Autodesk logo
Laurent Pallarès
Product Support Specialist
Autodesk, Inc.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Member
yves.menard
Message 3 of 15 (7,147 Views)
06-04-2012 04:41 AM in reply to: yves.menard
I use Autocad 2013 with Windows 7 (64b).
When I'm in explorer and select a file for starting Autocad, I can see the file in the preview area.
But when Autocad is open, I can't see no more file because the preview window does not exist.
Product Support
Laurent.Pallares
Message 4 of 15 (7,140 Views)
06-04-2012 05:32 AM in reply to: yves.menard
Reinitializing the user profile was the solution.
One of the profiles of AutoCAD Mechanical was corrupt.
Thanks for your collaboration :smileyhappy:
Best Regards
Autodesk logo
Laurent Pallarès
Autodesk, Inc.
Member
yves.menard
Message 5 of 15 (7,136 Views)
06-04-2012 05:38 AM in reply to: yves.menard
Thank you Laurent
Un gros merci Laurent.  Excellent service de ta part.
Valued Mentor
hardin
Message 6 of 15 (6,379 Views)
11-27-2012 07:58 AM in reply to: Laurent.Pallares
What setting or variable does this? Our Open Preview is missing too. If I set the profile to the <<unnamed>> then I get the preview pane during the open dialog box. Otherwise I don't. I remember (ages ago) some utility that compared settings in drawings or profiles.... anyone remember what that is?
Valued Mentor
hardin
Message 7 of 15 (6,372 Views)
11-27-2012 09:06 AM in reply to: Laurent.Pallares
This worked for me!
- Check that next key in the registry is setup = 1: KEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B001:409\Profiles\your profile\Dialogs\Select File   - PreviewVisible =1
(Of course some paths were a bit different. The thing to look for is your Profile)
Thanks.
Seems there should be a variable or setting of some sort in AutoCAD for this.
JamaL9722060
Message 8 of 15 (5,402 Views)
04-03-2013 02:30 PM in reply to: yves.menard
I have this problem but the other way around!
The preview shows the drawing but as the file is open it is not there! What is shown in the preview is not on the file (screenshot is attached)!
What might be the issue here?
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
*Expert Elite*
pendean
Message 9 of 15 (5,387 Views)
04-03-2013 06:26 PM in reply to: yves.menard
Jamal, see your other post.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
trwatkins
Message 10 of 15 (5,339 Views)
04-04-2013 06:19 PM in reply to: yves.menard
I am having the same problem.  The file will preview but when I open it is blank.  Tried to put in a ticket but couldn't because there wasn't an option to pick a program.  GRRRRRR.  Any help is greatly appreciated.
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
