AutoCAD Forum
AutoCad 2015 crashes after Start
3 REPLIES 3
ferdinand.haag
7461 Views, 3 Replies
Hi
Ive Instlled Autocad 2015 (studentlicence) on my Workstation (Dell Precision M6800 i7 ExtremeCore 32GBRam Nvidia Quadron/Win8.1 x64) and it worked fine till the last Windows Update
Now The Inventor and Autocad as well as the Mecanical Suite crashes direkt after the Startup.
Ive tried all solutions in the FAQ... but nothing helped...
any Idea here?
Thanks in advance!
3 REPLIES 3
If you are sure that's because of Windows Update, you can try to uninstall the update. Go to Windows Program and Features. There's link "View Installed Updates" at the left sidebar. Uninstall the update from there.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
Hi
Thank you for ur reply.
I found the reason - Windows switsched of the automatic start of the Licensing module which causes in an crash without notification. - Just switsching the service (FlexNet Licensing Service 64) to automatic start again - and it will work again.
It would be extremely helpful If one could get an hint that this service isnt started - instead of a total crash of this produkt.
Greeds
pendean
in reply to: ferdinand.haag
Thanks for sharing the fix you found.
”Boost
