AutoCAD Forum
AutoCAD2014 SP 1 Update installed, and now no manually entering dimensions
5 REPLIES 5
AndrewS_MBI
562 Views, 5 Replies
I just updated to AutoCAD 2014 Service Pack 1.  Now when creating solids, I don't see the options of manually entering the dimensions.  Is there a setting somewhere that needs to be switched back on?
5 REPLIES 5
nestly2
in reply to: AndrewS_MBI
Welcome to the AutoCAD forums.
Can you be more specific about what command you're using, what happened previously when you used the command compared to what's happening now?
AndrewS_MBI
When using the toolbar, selecting any of the solid objects on the Solid tab would give me the option of selecting the center point, x and y dimensions (radius for sphere, cylinders, etc.), and height.  The options appeared sequentially as tool-tip-like prompts once I clicked in the drawing window.
nestly2
Is Dynamic Input turned on? (status bar toggle or F12)
sthompson1021
You have got your dynamic input turned off is what you are describing.
AndrewS_MBI
in reply to: nestly2
Nestly and Sthompson1021, that was it exactly. I knew it was something small and stupid I was missing.
Thank you both!
”Boost
