I would like to have two icons on my desktop - both should fire up AutoCAD. But before AutoCAD starts up a file needs to be copied into a folder (depending which icon I click a different file gets copied).
I'm just wondering how I could get that done - can somehone point me in the right direction?
I could create two scripts (and desktop shortcuts)- each script copies a specific file first before executing AC exe.
But the standard Windows shortcut contains a "start in" property I'm not sure how to deal with. In my AC map shortcut it points to:
"C:\Program Files\Autodesk\AutoCAD Map 3D 2013\UserDataCache\"
Do I need to take it into account? If so - how?
Or are there any other approaches?
Many thank, Rob
Solved by Alfred.NESWADBA. Go to Solution.
yep, script would be what you are looking for.
And to start AutoCAD from a specific folder use that lines in your script:
rem your copy action copy <from_file> <to_file> rem change active drive to drive C C: rem change the working folder CD "\Program Files\Autodesk\AutoCAD Map 3D 2013\UserDataCache\" rem start acad.exe with profile, workspace, other parameter "C:\Program Files\Autodesk\AutoCAD Map 3D 2013\acad.exe" /product MAP /language "en-US"
HTH, - alfred -
