AutoCAD 2013/2014/2015
Valued Contributor
Message 1 of 6 (171 Views)
AutoCAD multi proccess when opening from vault
171 Views, 5 Replies
01-16-2013 06:10 AM
good day,
one of our users is opening AutoCAD from Vault, accessing his files this way.
but every file we open, the AutoCAD installed open up a new process, resulting in multi AutoCAD applications.
so If I have 4 drawings open, I have 4 processes of vault open,
is this a Vault issue
Product Support
Kevin.Jaufmann-Ludwig
Message 2 of 6 (151 Views)
Re: AutoCAD multi proccess when opening from vault
01-17-2013 07:37 AM in reply to: jacoj
Dear jacoj,
to verify if this is a Vault issue: what happens if you open an AutoCAD DWG from Windows Explorer if AutoCAD is already opened. Is there a new AutoCAD opened as well?
Kevin Jaufmann-Ludwig
Technical Support Specialist
Customer Service & Support
Valued Contributor
Message 3 of 6 (138 Views)
01-17-2013 09:44 PM in reply to: jacoj
sorry I mentioned i have multi applications Vault, I have multiple AutoCAD applications running,
opening files from the Vault.
so every time I open AutoCAD even from explorer, its opens up another application, which happens on my machine as well, but in my machine it opens up only one application of AutoCAD when opening from vault, where the users machine if you open from explorer autoCAD it opens multi applications and open drawings from vault open multiple applications.
resulting in multi proccesses running instead of one.
kind regards.
JGerth
Message 4 of 6 (125 Views)
01-18-2013 05:24 AM in reply to: jacoj
compare the SDI value on both machines.  just type SDI at a command line.
Same, or diffrerent?
Valued Contributor
Message 5 of 6 (102 Views)
01-20-2013 11:32 PM in reply to: jacoj
Good day.
I did check the SDI command, previously, and now again, but both machine settings are set to the default "0"
command.
pendean
Message 6 of 6 (96 Views)
01-21-2013 05:40 AM in reply to: jacoj
have you tried posting and asking in the VAULT forum? It might be an overlooked ability that needs to be turned off http://forums.autodesk.com/t5/Autodesk-Vault/ct-p/2004
If this same user logs into another PC, does the problem move with them?
If someone else logs into this user's PC, does the problem go away?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
