Hi, when creating a schedule with a simple formula column (e.g : [QUANTITY]*Width), the formula column total doesn't add the formula results for a grand total. The total shown is the addition of Width of element.
If I try and enable "Apply formula to totals", the total is : total quantity*total width instead of just a simple addition of formula resulting values.
For example:
I have 4 windows of 2 different styles.Two windows have a width of 2 meters, the other 2 windows have a width of 3 meters. I want to find out, my total window width, of all window styles.Therefore, i make a schedule with the following columns: QUANTITY, WIDTH and TOTAL WIDTH. The total width column is a formula column (Quantity*Width). The total of the formula column (Quantity*Width) doesn't add the resulting values (2*2+3*2=10), it only adds the simple widths without multiplication with quantity, my result is 5, wich is incorect. If i enable "Apply formula to totals", it multiplies total quantity (4) by total width (5).
I need a solution for having the corect total on the formula column.
Thank you,
Alexandra Rus
Hello again,
I attached the DWG file with the problem schedule.
Thank you for your reply.
I think i figured out what the problem is.
My WIDTH column TOTAL is already multiplied by the quantity.
I'm sorry for the missunderstanding.
Thank you again,
Alexandra Rus
