These are the current available Object Enablers for 2015 products.
Cheers,
Volker.
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
The Architecture and MEP Object Enabler is included within AutoCAD and all AutoCAD-based products. So there is no need to post a separate installer unless there are some code changes that affect users of the OE. For this release, there have been not yet been any changes (i.e. defect fixes) that affect the Object Enabler. Therefore no OE Installer.
Are you looking for an OE Install just because it is usually present? Or is there some specific issue you've encountered?
Thanks, Bill Glennie
AutoCAD Architecture and MEP Team
It never used to be...
In the previous version, all users of AutoCAD, AutoCAD LT and TrueView had to download the object enabler to see objected created in MEP.
Are you saying this has changed in all 2015 versions?
If so, why is it only the Architecture-MEP object enabler that is included?
Just for the record, I have tried to open an MEP drawing in AutoCADLT 2015 and TrueView 2015 and I get the proxy warning box and no objects are visible.
The Architecture & MEP Object Enabler has been part of the AutoCAD, LT and TrueView initial release for a few years. I do not know exactly when it started, but the 2013 and 2014 releases certainly included them. The Architecture and MEP enabler has been part of AutoCAD for quite a few years, perhaps since 2007 or before, and we always synchronize our file format changes with the platform. This means that there are no issues when exchanging files as long as the base AutoCAD file format matches.
If possible, please send this MEP drawing to me (bill(dot)glennie(at)autodesk(dot)com) and I will investigate why the objects are not appearing immediately in AutoCAD LT and TrueView.
Thanks, Bill
This is so confusing. Below are the download links for the previous versions:
2014
2013
2011
Although there doesn't seem to be a 2012 version, why where they supplied as a separate download if they are already supplied?
I will send you a sample file.
