How is the Selection Cursor Badge turn off? It's very, very annoying. I know if the selection is going to be a crossing because the selection border is dashed and the selection is window because the border is solid (continuous).
Solved by scottmoyse. Go to Solution.
tygelb wrote:
Now it's down to the MATCHPROP icon. Can't find a way to get rid of that one either.
You cant, and yes, the MATCHPROP icon was in 2011-2014, just as it was in much earlier releases. You apparently had the ability not to notice it in the previous versions, so that's the solution now as well
This sounds interesting...so: how can i turn off that yellow dashed line?
Thanks!!!
Hello
Welcome to the Autodesk/AutoCAD Forums !
Not sure to well understand that you are asking for !?
OPTIONS / Selection Tab / Bottom-Right
Please switch OFF 2 options : Preview for commands AND Properties !?
Regards, Patrice (I am not an Autodesk Advisor)
Patrice BRAUD
Sorry! I realize i wasn´t so clear....i mean the yellow dashed line that appears when you use the MOVE commands.Thanks!
Hello
YES it's non-configurable !
Patrice BRAUD
