I noticed today that the new Layout Tab bar in AutoCAD 2015 has removed the capability to duplicate a layout by holding down the Ctrl key and dragging the layout to be copied. The 5-click-move-your-cursor-all-over-the-screen method is still there, but obviously the 1-click method was superior.
Solved by nrz13. Go to Solution.
Solved by LyleHardin. Go to Solution.
Autodesk is aware of the new issue with the tabs re-ordering themselves. The issue is being investigated for a possible fix.
Thanks for the update, Shawn.
Here's a link to the hotfix for the tab reordering bug after installing SP2:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoca...
