I've installed AutoCAD 2015 and now working on it. I have issues with my graphics card - I've got Intel(R) HD Graphics 3000 with following details from the Tuner Log (see below) I tried searching for updates for this graphics card and I failed to find.
Any help to get this card up and running for the new features in AutoCAD 2015.
Card name: Intel(R) HD Graphics 3000
Driver version: 9.17.10.3347
Tuning Date: 31/03/2014
Virtual device: gdi12.hdi (Software)
The card and driver does not meet the minimum requirement.
Display Adapters:
Intel(R) HD Graphics 3000(Primary)
Certification:
Hardware Available False
Hardware Recommended False
Status 5
Hardware ID 8
Hardware Feature Level 0
Software Feature Level 50
Failed Devices D3D11,D3D9
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Additional System Information:
ComputerSystem
Manufacturer Hewlett-Packard
Model HP Pavilion dv7 Notebook PC
NumberOfProcessors 1
TotalPhysicalMemory 8535257088
Processor
MaxClockSpeed 2001
Name Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
NumberOfCores 4
NumberOfLogicalProcessors 8
Revision 10759
OperatingSystem
Name Microsoft Windows 8 Pro with Media Center|C:\WINDOWS|\Device\Harddisk0\Partition2
OSLanguage 2057
ServicePackMajorVersion 0
ServicePackMinorVersion 0
TotalSwapSpaceSize
TotalVirtualMemorySize 9580396
Version 6.2.9200
DiskDrive
Model TOSHIBA MK7575GSX
Name \\.\PHYSICALDRIVE0
Size 750153761280
DesktopMonitor0
MonitorManufacturer (Standard monitor types)
MonitorType Generic PnP Monitor
Name Generic PnP Monitor
ScreenHeight
ScreenWidth
DesktopMonitor1
MonitorManufacturer
MonitorType Default Monitor
Name Default Monitor
ScreenHeight 900
ScreenWidth 1600
DisplayConfiguration
DeviceName Intel(R) HD Graphics 3000
DisplayFrequency 60
DriverVersion
PelsHeight 768
PelsWidth 1024
VideoController0
AdapterDACType Internal
AdapterRAM 2176843776
ConfigManagerErrorCode 0
CurrentHorizontalResolution 1600
CurrentVerticalResolution 900
DriverDate 20140129000000.000000-000
DriverVersion 9.17.10.3347
InstalledDisplayDrivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Status OK
TimeOfLastReset
VideoArchitecture 5
VideoModeDescription 1600 x 900 x 4294967296 colors
VideoController1
AdapterDACType
AdapterRAM
ConfigManagerErrorCode 43
DriverDate 20120619000000.000000-000
DriverVersion 8.97.10.6
InstalledDisplayDrivers aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64
Name AMD Radeon HD 7400M Series (Microsoft Corporation - WDDM v1.20)
Status Error
TimeOfLastReset
VideoArchitecture 5
Process Information:
Loaded ARX and CRX Modules
acapp.arx
acapp.crx
acautoloader.arx
accloudconnect.crx
acvmtools.crx
vl.crx
aclaunchnfw.arx
acsign.arx
acetutil.arx
vl.arx
acdwgfeed.arx
acjscorestub.crx
acexperience.arx
acpublish.crx
acpublish.arx
AcPi.arx
acconnectwebservices.arx
acdim.arx
acdim.crx
AcFdUi.arx
acgsconfig.arx
acgsconfig.crx
Effects:
ACAD_LineSmoothing supported turned on
ACAD_PerPixelLighting not supported turned off
ACAD_AdvancedMaterial not supported turned off
ACAD_FullShadows not supported turned off
ACAD_TextureCompression not supported turned off
what issues do you have, you have not mentiioned anything, just listed the log.
If it's the list of none-supported effects from the log:
Viewing >>>that comparisions<<< I guess the HD3000 does not support the effects that AutoCAD needs within DirectX11.
So it's not the drivers, it's the hardware, so I guess any software update will not bring that effects to live.
>> [from dialog] Driver version: 9.17.10.3347
I have found >>>version 15.28<<<, but it's not sure that the release number you get listed in the hw-acceleration dialog is the same number as listed in the drivers list from Intel.
- alfred -
>> I have this issue
I don't understand, sorry. What is "this" issue?
Or did you attach an image via mail that is not uploaded here? In that case use the forum access to that thread for answering and not the mail.
- alfred -
It looks like I have this issue in my Device Manager
Well, that's not a problem with the Intel HD 3000, you should find the driver for your AMD gc (from AMD or from your workstation hardware vendor) and install it (with admin permissions).
Have you tried that?
- alfred -
BONJOUR;
jai un porbleme d'accelerateur graphique sur autocad 2015 que j'arrive pas aresoudre merci
cordialement
and what problem do you have?
- alfred -
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
If you have problem to write in US/English, please post into the French Forum !
http://forums.autodesk.com/t5/AutoCAD-Francais/bd-p/127
... Nous avons des personnes francophones competentes sur ce forum Francais ...
Patrice BRAUD
