In AutoCAD 2015, I could not import a set of files (Layouts) into the Sheet Set Manager because it wrongly implied that the characters I was importing were more than 64 characters. After a few tries, I opened 2014 and they imported smoothly. I have abandoned 2015 until I have a solution.
On the second machine with 2015, it will not work also, however, right-click on the layout tab and "Import Layout To Sheet Set" works. This is tideous if you have lots of file so import.
Any solutions?
@omorah wrote:In AutoCAD 2015, I could not import a set of files (Layouts) into the Sheet Set Manager because it wrongly implied that the characters I was importing were more than 64 characters. After a few tries, I opened 2014 and they imported smoothly. I have abandoned 2015 until I have a solution.
Any solutions?
No solution so far.... I hope Autodesk can develop patch for older versions.....
How about new versions 2016; 2017; 2018? Any improvements?
@AIR_123: 'How about new versions 2016; 2017; 2018? Any improvements?'
Well, I just installed AutoCAD 2022 and got the error described above...even though I personally have never come across this in any previous version to date. And this included the update from last month!
