So I tried to install the .NET framework manually, but it was already installed. I get an error message after some loading during the instalation. "Installation complete. Some products failed to install". I have my windows firewall turned off.
Here is the log file:
2014/2/8:01:15:46 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:15:46 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:15:46 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AIA66B.tmp
2014/2/8:01:15:46 spanyi SPANYI-PC Launch
2014/2/8:01:15:46 spanyi SPANYI-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\spanyi\AppData\Local\Temp\_AIA66B.tmp\Setup\AcSetup.dll
2014/2/8:01:15:46 spanyi SPANYI-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/8:01:15:47 spanyi SPANYI-PC PageOpen LaunchDialog
2014/2/8:01:15:51 spanyi SPANYI-PC PageOpen LicenseDialog
2014/2/8:01:15:54 spanyi SPANYI-PC PageOpen ProductInfoDialog
2014/2/8:01:16:30 spanyi SPANYI-PC PageOpen ProductSelectionDialog2
2014/2/8:01:16:32 spanyi SPANYI-PC PageOpen FullProgressDialog
2014/2/8:01:16:32 spanyi SPANYI-PC Installing .NET Framework Runtime 4.0 Language Pack: "C:\Users\spanyi\AppData\Local\Temp\Rar$EX01.298\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1038.exe" /q
2014/2/8:01:16:40 spanyi SPANYI-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/2/8:01:16:40 spanyi SPANYI-PC PageOpen InstallCompleteDialog
2014/2/8:01:17:28 spanyi SPANYI-PC === Setup ended ===
2014/2/8:01:15:44 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:15:44 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:15:44 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\Rar$EX01.298
2014/2/8:01:15:44 spanyi SPANYI-PC Launch
2014/2/8:01:15:44 spanyi SPANYI-PC CommandLine
2014/2/8:01:15:44 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AIA66B.tmp
2014/2/8:01:26:06 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:26:06 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:26:06 spanyi SPANYI-PC Current Directory D:\torrent\AutoCAD Architecture 2014 English (x32)&(x64)
2014/2/8:01:26:06 spanyi SPANYI-PC Launch
2014/2/8:01:26:06 spanyi SPANYI-PC CommandLine
2014/2/8:01:26:06 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AI2676.tmp
2014/2/8:01:26:19 spanyi SPANYI-PC === Setup ended ===
2014/2/8:01:26:10 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:26:10 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:26:10 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AI2676.tmp
2014/2/8:01:26:10 spanyi SPANYI-PC Launch
2014/2/8:01:26:12 spanyi SPANYI-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\spanyi\AppData\Local\Temp\_AI2676.tmp\Setup\AcSetup.dll
2014/2/8:01:26:12 spanyi SPANYI-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/8:01:26:18 spanyi SPANYI-PC PageOpen LaunchDialog
2014/2/8:01:26:24 spanyi SPANYI-PC PageOpen LicenseDialog
2014/2/8:01:26:26 spanyi SPANYI-PC PageOpen ProductInfoDialog
2014/2/8:01:26:55 spanyi SPANYI-PC PageOpen ProductSelectionDialog2
2014/2/8:01:26:57 spanyi SPANYI-PC PageOpen FullProgressDialog
2014/2/8:01:26:57 spanyi SPANYI-PC Installing .NET Framework Runtime 3.5 SP1: "D:\torrent\AutoCAD Architecture 2014 English (x32)&(x64)\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/2/8:01:27:27 spanyi SPANYI-PC Install .NET Framework Runtime 3.5 SP1 Succeeded
2014/2/8:01:27:27 spanyi SPANYI-PC Installing .NET Framework Runtime 4.0 Language Pack: "D:\torrent\AutoCAD Architecture 2014 English (x32)&(x64)\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1038.exe" /q
2014/2/8:01:27:34 spanyi SPANYI-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/2/8:01:27:34 spanyi SPANYI-PC Rollback .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1619
2014/2/8:01:27:35 spanyi SPANYI-PC PageOpen InstallCompleteDialog
2014/2/8:01:33:14 spanyi SPANYI-PC === Setup ended ===
2014/2/8:01:41:25 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:41:25 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:41:25 spanyi SPANYI-PC Current Directory D:\torrent\AutoCAD Architecture 2014 English (x32)&(x64)
2014/2/8:01:41:25 spanyi SPANYI-PC Launch
2014/2/8:01:41:25 spanyi SPANYI-PC CommandLine
2014/2/8:01:41:25 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AI2DF4.tmp
2014/2/8:01:41:32 spanyi SPANYI-PC === Setup ended ===
2014/2/8:01:41:28 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:41:28 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:41:28 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AI2DF4.tmp
2014/2/8:01:41:28 spanyi SPANYI-PC Launch
2014/2/8:01:41:28 spanyi SPANYI-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\spanyi\AppData\Local\Temp\_AI2DF4.tmp\Setup\AcSetup.dll
2014/2/8:01:41:28 spanyi SPANYI-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/8:01:41:30 spanyi SPANYI-PC PageOpen LaunchDialog
2014/2/8:01:41:39 spanyi SPANYI-PC PageOpen LicenseDialog
2014/2/8:01:41:41 spanyi SPANYI-PC PageOpen ProductInfoDialog
2014/2/8:01:42:09 spanyi SPANYI-PC PageOpen ProductSelectionDialog2
2014/2/8:01:42:11 spanyi SPANYI-PC PageOpen FullProgressDialog
2014/2/8:01:42:11 spanyi SPANYI-PC Installing .NET Framework Runtime 4.0 Language Pack: "D:\torrent\AutoCAD Architecture 2014 English (x32)&(x64)\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1038.exe" /q
2014/2/8:01:42:17 spanyi SPANYI-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2014/2/8:01:42:18 spanyi SPANYI-PC PageOpen InstallCompleteDialog
2014/2/8:01:42:23 spanyi SPANYI-PC === Setup ended ===
2014/2/8:01:42:31 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:42:31 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:42:31 spanyi SPANYI-PC Current Directory D:\torrent\AutoCAD Architecture 2014 English (x32)&(x64)
2014/2/8:01:42:31 spanyi SPANYI-PC Launch
2014/2/8:01:42:31 spanyi SPANYI-PC CommandLine
2014/2/8:01:42:31 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AI2F66.tmp
2014/2/8:01:42:38 spanyi SPANYI-PC === Setup ended ===
2014/2/8:01:42:34 spanyi SPANYI-PC === Setup started on SPANYI-PC by spanyi ===
2014/2/8:01:42:34 spanyi SPANYI-PC Path_Length: 155
2014/2/8:01:42:34 spanyi SPANYI-PC Current Directory C:\Users\spanyi\AppData\Local\Temp\_AI2F66.tmp
2014/2/8:01:42:34 spanyi SPANYI-PC Launch
2014/2/8:01:42:34 spanyi SPANYI-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\spanyi\AppData\Local\Temp\_AI2F66.tmp\Setup\AcSetup.dll
2014/2/8:01:42:34 spanyi SPANYI-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/8:01:42:36 spanyi SPANYI-PC PageOpen LaunchDialog
2014/2/8:01:42:40 spanyi SPANYI-PC PageOpen LicenseDialog
2014/2/8:01:42:42 spanyi SPANYI-PC PageOpen ProductInfoDialog
2014/2/8:01:42:52 spanyi SPANYI-PC PageOpen ProductSelectionDialog2
2014/2/8:01:42:55 spanyi SPANYI-PC PageOpen FullProgressDialog
2014/2/8:01:42:55 spanyi SPANYI-PC Installing .NET Framework Runtime 4.0 Language Pack: "D:\torrent\AutoCAD Architecture 2014 English (x32)&(x64)\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1038.exe" /q
2014/2/8:01:43:01 spanyi SPANYI-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
Thanks for your help 🙂
What is this?
Where did you download the install files from (url)?
Where are the install files (drive)?
