Solved by mefloump. Go to Solution.
There is a better way to import points into a drawing by select a coordinates file instead of using script.
Script sounds too painful for me.
I am currently working on AutoCAD Mechanical Network Version 2014. While installing the given source setup.exe file using below commands:
INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014"
ACADSERIALPREFIX="393"
ACADSERIALNUMBER=" 94539329 "
ADLM_PRODKEY=" 783F1"
ACDFIRSTNAME="A"
ACADLASTNAME="User"
ACADORGANIZATION=User Corporation"
INSTALLLEVEL=5
All the components are being installed expect AutoCAD Mechanical 2014, it is giving below error when the installation reached this point.
I have raised a request with the vendor for the installation of the software but did not find response. Please find attached email sent to the vendor.
Checked log file and found the sequence of installation of the components and tried to install them individually, but few components like Autodesk Inventor 2014 is using Standalone.mst which I’m not able to install. Please find attached log file with the sequence of installation and the commands. Tried using the following command to install the standalone.mst file.
<path of msi> TRANSFORMS=”1.mst;standalone.mst” but it is throwing below error
Thanks a lot. I had faced the problem for running the script file while osnaps are on. as I am not getting the expected result from the Script file. But when I off the osnap and then after running the script file it works very well.
Thnaks & Regards.
