I have a workstation that will not print random attributes. We have several attributes we have placed in the drawing and almost all print however 1 or 2 per file do not print. There seems to be no pattern to this. For example the attached file has 'Numbered Notes' at the top left. The number of the note prints ok in notes 1-4, but the number 5 does not. The text for note 5 is there but the five does not show up. The attached pdf is to show what result we are getting when printing this file.
We have tried printing the same file on another workstation, to another plotter and to another 11x17 printer and all work just fine
Solved by dmfrazier. Go to Solution.
Assuming each workstation is using a separate PC3 file, check and compare the settings for the DWG to PDF.pc3.
This may seem like a wild guess (because it is!), but try the Font handling settings shown below:
