When I alter a Workspace it doesn't hold it's settings as I switch back and forth between them. I altered the Drafting & Annotation Workspace to suit my needs. If I change to 3D Basics or 3D Modeling workspace then switch back to Drafting & Annotation then the changes I made to Drafting & Annotation are gone. I tried to work around that by making a custom workspace. When I change out of the custom workspace into another workspace then go back into the custom workspace then it keeps my settings except for one thing: it always turns on the Model and Layout Tabs which I specifically turned off in the custom workspace.
Another thing I can't figure out is how to turn on a Toolbar in the 3D Basics or 3D Modeling workspaces.
I'm just recently upgrades to AutoCAD 2014 from AutoCAD 2006 and am not liking the whole workspace idea. It's too much switching around and it seems to be less efficient than what I was using in 2006. Suggestions are welcome, especially if they involve retiring and never using AutoCAD again!
Solved by nestly2. Go to Solution.
Workspaces can be saved two ways.... automatically or manually. Both have their advantages and their disadvantages. Personally I prefer manual, but as you've discovered, you have to remember to save after modifying or your changes will be lost.
To turn on/off toolbars from the Ribbon in 2014, click on the "View" ribbon tab, then pick "Toolbars" in the "User Interface" tab.
Regarding Workspaces; I think if you give yourself some time to get used to them, you may find them an improvement, however if you simply want a single user interface, create a new workspace based on the AutoCAD "Classic" interface and turn on all the same toolbars you used in 2006. One workspace for everything... problem solved.
It's 4:00 in the afternoon. Do you know where your workspaces are? No, really - are you working from a workspace in the Main or Enterprise? If the latter, then changes cannot be saved. If the former, you may not be loading that Main with the profile you are choosing (profile selects Main and Enterprise; Main and Enterprise determine which workspaces are available).
I rather like workspaces from a management perspective. By saving them in the Enterprise CUIx, my users have a common starting point to work from. When they save (everybody has their own Main), its saved to a network location that is covered by nightly backups. If a user has a computer failure, they don't lose their UI settings.
Ahh...perfect! Thank you for that perfectly clear explanation and the video. Now I'm enlightened.
Do you have any resource for setting this up? I would like to experiment with such a setup for the 2015 release when we receive it. A lot of users at my company have their own custom workspaces, and I've found that migrating doesn't always work - in fact it tends to "break" more than it helps.
We don't migrate workspaces between versions. There's too many new elements, discontinued elements, different partial CUIx files, etc. to reliably carry over. When a new AutoCAD version is rolled out the new Enterprise is built with the set of common workspaces they can start from. There's some grumbling of course, but its not something we do every year and I try to keep the Enterprise workspaces close to what the majority is using.
As for set-up, thats the easy part - just locate the Main CUIx on a network drive folder with full access for indiviudal user. We have common path names here so there's no user name/ID to parse out into the path or filename.
To All
Looking to see if the solution posted will help me with our situation also:
Custom CUI or Workspace Settings
As usual, any information or help would be appriciated. Thanks again.
