AutoCAD 2013/2014/2015
New Member
Message 1 of 2 (1,717 Views)
AutoCAD 2013 Won't Open File
1717 Views, 1 Replies
12-01-2012 12:07 PM
My AutoCAD will not allow me to open my recently used file. It keeps coming up with a message saying:
'Drawing File is not Valid'
Please help me to overcome this problem.
Moiz Khan
*Expert Elite*
Alfred.NESWADBA
Message 2 of 2 (1,712 Views)
Re: AutoCAD 2013 Won't Open File
12-01-2012 12:48 PM in reply to: khan_moiz786
first create a backup from your BAK-file (and rename it to .DWG, with a little bit luck it's a valid drawing from your last save-command.
Then you can start AutoCAD (with an empty drawing), start command _RECOVER and show your defect file to get repaired.
If that does not work, you can try command _DRAWINGRECOVERY, that brings up the recover-manager with drawings recognized by autosave when AutoCAD crahsed. If you find your drawing in the list you (hopefully) find the SV$-file (that's created by autosave), double click it to open it.
If that does not help, use your BAK, if that also fails you have to restore the file from your last backup.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
