AutoCAD Forum
AutoCAD 2013 Text Properties freezes AutoCAD
4 REPLIES 4
Shulshah
987 Views, 4 Replies
i have one problem if any one can help me???
i am using AutoCAd 2013 and also 2007. my problem is that i always received file from survey department. when i select text properties of that file autocad freezes for few min so i can't work with text properties. all other things fine .
i tried purge audit. block object even wblock object but same problem. save file is dxf but nothing.
4 REPLIES 4
pendean
in reply to: Shulshah
Are you constantly turning AutoCAD off and back on when you open files?
Does the problem go away (after the initial 'freeze') if you keep AutoCAD open all day and simply use OPEN and CLOSE commands to access your files?
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
The survey department is using WHICH AutoCAD ? or maybe an other CAD program ?
- Have you tried to open DWG in RECOVER Mode ?
Do you see some errors ??
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Shulshah
in reply to: pendean
i face this problem from 15 days. i restart computer also. when i click text its fine but i open properties box then it become freeze for 4 to 5 min if again i open properties box it become again freeze. only problem with those files which coming from survey department (Civil 3D) files. other files no issue
Shulshah
in reply to: braudpat
thanks, they are using civil 3D i need to make some text changing always. my other files no issue
”Boost
