i have one problem if any one can help me???
i am using AutoCAd 2013 and also 2007. my problem is that i always received file from survey department. when i select text properties of that file autocad freezes for few min so i can't work with text properties. all other things fine .
i tried purge audit. block object even wblock object but same problem. save file is dxf but nothing.
Hello
Welcome to the Autodesk/AutoCAD Forums !
The survey department is using WHICH AutoCAD ? or maybe an other CAD program ?
- Have you tried to open DWG in RECOVER Mode ?
Do you see some errors ??
Bye, Pat
Patrice BRAUD
