good morning. my mouse wheel worked for panning while i am in the middle of a command, put now it stopped working and when i click the wheel i get my osnaps command. how can i get my mouse wheel to pan again?
thank you
Solved by pendean. Go to Solution.
Adding to this post for others who have similar issues but the solution by heinsite did not work.
I have a Logitech wireless keyboard and mouse combo as does another operator in my office. For some reason several weeks ago I was no longer able to pan with the wheel in cad. However a wired mouse worked, as did a different logitech wireless mouse. Then today, my wireless keyboard went down. I swapped with the other user who had found her mouse was no longer panning. That fixed her problem (she could pan with the mouse that I was unable to pan with), but her keyboard still didnt work on my computer.
Solution:
Hope this works for the rest of you.
By the way, this had nothing to do with AutoCad other than that is the program where most of us pan with the wheel mouse. I had the same issue with my cad based survey software (MicroSurvey which is built on the intellicad engine) and AutoCad Map 3d 2015.
@rainmanoliver1 wrote:Probably a bit late to help the original posts, but I was experiencing the same issue this morning. What fixed it for me was toggling the 'insert' button on my keyboard. Don't ask why this worked, but it did.
Dell laptop, using laptop keyboard and wireless Logitech M510 mouse.
Hopel that is of help to someone else out there...
-rC
Rainman - you did it! Nothing else fixed it but your tip on the insert key. THANK YOU!!!!!
Set Scroll wheel (forget Autoscroll, and Universal Scroll), to "Other" and then set it to "Middle Button".
That will allow you to use it to pan when the wheel is depressed and zoom when the wheel is rotated.
@Anonymous wrote:I'm using AUTOCAD LT 2014. My middle mouse button (wheel) will control zoom but it will not pan when I click the wheel. I'm using a Logitech wireless mouse. MBUTTONPAN is set to 1. I've checked all settings in the control panel. The wheel works perfectly fine in all other programs.
I've tried establishing a new button in the mouse control under the Manage Tab on the ribbon. It seems like that might be the solution but I need some guidance.
Any sincere help will be appreciated.
I had exactly the same problem, but I just unupagrade the mouse controller.
1. Control Panel
2. Hardware and Sound
3. Devices and Printers
4. USB Receiver (which in my case is my keyboard and my mouse) > Properties
5. Hardware > Select Mouse HID-Compliant
6. Properties
7. Controller > Driver Rollback
I have a Wireless Logitech Optical Mouse (from Cordless Desktop EX-100), I hope it can help you too.
My dad found something more interesting for the people who have the EX-100 keyboard. It is called SetPoint, which would be the driver of the keyboard. You just need to install de product (here is the link), which is free, and go to mouse option, it says "Cordless Optical", go to Button Settings and there, in the number 3 button, you must select the option "other" and look for "Generic Button" in the list below. Apply, and it's done.
SetPoint Configuration > Cordless Optical > Button #3: Other > Generic Button
Link: http://support.logitech.com/en_us/product/cordless-desktop-ex-100-product
Same problem for me. I tried everything that was suggested on here (MBUTTONPAN, Windows mouse settings, new batteries, etc...) I eventually switched the USB port and restarted the computer and that worked.
How do I get to my mouse settings? I am using windows with a microsoft mouse, but I dont know where the mouse settings are located. Please help!
AutoCAD Educational 2015 version.
The first place you might want to check is within Windows itself. Got to the Control Panel from your Start button and look for "Mouse" in the Computer's Settings list. Within that you can change a number of settings and assignments.
The next place to look is within AutoCAD itself. Right click anywhere in a drawing and select Options. In the System tab you can check the settings in the panel titled Current Pointing Device.
Another option is to use any specific mouse software that might have come with your device.
Dave.
I notice something interesting on my windows 10 Dell laptop. When I start autocad as administrator, mid pan button does not work. If I simply start autocad without administrator rights, mid button works fine.
I use wireless Logitech M560 mouse nad K270 keyboard.
Does anyone have any suggestions on how to get my scroll wheel to pan in Inventor? I opened up a drawing this morning and it was working. Now it won't respond. It also does it with a model as well.
Thanks.
Hi.
Just got the fix: configure the button 7 (change app) to center button like the pic attached, that makes pan Works in Autocad 2017, I think because center button when pressed change the way it behaves. (linear or with cliks, you cant make it work when pushed) LOGITECH M560
