AutoCAD 2013/2014/2015
New Member
Message 1 of 12 (39,311 Views)
Accepted Solution
AutoCAD 2013 Heidi driver problem acaddm11.hdi missed
39311 Views, 11 Replies
04-06-2012 08:48 AM
Hi, I downloaded AutoCAD 2013 for Windows 64bit, installed it. But when I run it, it shows up an error window saying "The configured Heidi driver cannot be loaded. Switching to default software driver". And when I try to change the view from the objects with the cube located in the superior right corner the same error shows up  saying "Error loading Heidi Module -C:\Program Files\Autodesk\AutoCAD 2013\Drv\acaddm11.hdi".
I've searched everywhere for a solution but I can't find anything. If anyone knows how to fix it please tell me.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 12 (39,295 Views)
Re: AutoCAD 2013 Heidi driver problem acaddm11.hdi missed
04-06-2012 10:04 AM in reply to: davidhervil
what graphic card do you have in your pc?
If you start command _3DCONFIG ==> manual tune ==> try here to change the checkbox for hardware accerlation.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
New Member
Message 3 of 12 (39,289 Views)
04-06-2012 10:19 AM in reply to: Alfred.NESWADBA
I have an Nvidia Geforce GT540M Cuda. I have already tried  the _3DCONFIG command and clicking the update cheking button but it says everything is ok. In manual tune what do I modify to fix the problem ?
*Expert Elite*
Alfred.NESWADBA
Message 4 of 12 (39,286 Views)
04-06-2012 10:22 AM in reply to: davidhervil
I don't know if that fixes your problem, but on top of the Manual-Tune-Dialog you have a checkbox for hardware-acceleration. Try to switch it of and restart AutoCAD to verify the issue.
Another option for getting closer to the problem would be if you login to your Windows with another user-account and try to start AutoCAD again.
- alfred -
Alfred NESWADBA
dk
New Member
Message 5 of 12 (39,053 Views)
04-19-2012 05:54 AM in reply to: davidhervil
Hi all,
I had the same error. It's was a DirectX-Setup failure.
Execute ..\3rdParty\DirectX\DXSETUP.exe by hand, and ACAD 2013 will work!
Cheers,
Daniel
Message 6 of 12 (27,890 Views)
01-17-2013 04:26 AM in reply to: dk
I was able to trace the issue to having the Job Processor for Vault Pro 2013 running and then locking my screen.  Kind of like you would do when you go home at night so the Job Processor would run over night creating visualizations.  I ran  DXSETUP and then tried the screen lock again.  I still got the error.  At least it's a very repeatable error.  Perfect for Autodesk Support.
Bill Schmid
AutoCAD Mechanical 2011
New Member
Message 7 of 12 (20,373 Views)
05-07-2013 07:24 AM in reply to: dk
Okay, please forgive my stupidity, but where would you find the 3rd party folder?  I used to have an Nvidia video card but have switched to an ati v7900.  It (AutoCAD MEP 2013) tells me it doesn't have a driver.  When i deleted the Nvidia programs, is when all this started.
Member
Message 8 of 12 (18,302 Views)
06-06-2013 03:34 PM in reply to: davidhervil
Finally achieved after many attempts to fix the problem with that stupid error autocad 2014
and is easier than it seems
1. - Open the registry you type Win + R enter regedit
2. - "Ctrl + F" we all entries "CustomHeidiDriverPath" and remove the value assigned to this
entry
C: \ Program Files \ Autodesk \ AutoCAD 2014 \ Drv \
attentively
yehosef
missing or corrupt display driver hdi
Autocad 2014
________________________________________________________________
Finalmente despues de muchos intentos logre solucionar el problema con ese estupido error del
autocad 2014
y es mas sencillo de lo que parece
1.- abrir el registro Win+R enter tecleamos regedit
2.- "Ctrl +B" buscamos todas las entradas "CustomHeidiDriverPath" y eliminamos el valor asignado
a esta entrada
C:\Program Files\Autodesk\AutoCAD 2014\Drv\
atentamente
yehosef
Autocad 2014
New Member
Message 9 of 12 (17,671 Views)
06-16-2013 09:38 PM in reply to: davidhervil
el programa de autocad 2014 no me quiere abrir porque me exige un codigo y una contraseña lo vaje por internet y no lo he podido usar, no se que me recomiendan. gracias
New Member
Message 10 of 12 (14,833 Views)
08-02-2013 05:55 AM in reply to: tigreroos
This missing Heidi driver made me sick, because none of the indikated paths here made AutoCad 2014 run on the PC of my colleque... but finally i got the solution, and it is very easy:
clicking right on the desktop going to Properties/Settings/Advanced/trouble-shooting and disable hardware acceleration by pushing the  actuator to none. try the result!
now as far as  i'am not sure how the menu points are named in the english windows version i hope you find the path by my translations.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
