AutoCAD Forum
Auto fraction stack
6 REPLIES 6
joe
1106 Views, 6 Replies
Auto fraction stack
I just switched from LT 2014 to LT 2015 and there is a change in Autostack I cannot seem to fix. In LT 2014 I would type the following
L31/2x31/2x1/4x11'-31/2"  and the 1/2 & 1/4  would stack and also delete the space between the numbers.
Now with LT2015, I type the same way and end with this  L3 1/2x3 1/2x1/4x11'-31/2" and the only fraction that stacks is the 1/2 on the end.
and I have to use Text Formating to highlight the fraction, right click the mouse button, then choose stack.
Does anyone have a fix?
Joe
6 REPLIES 6
nrz13
in reply to: joe
This is a known bug:
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Autostack-Bug-2015/m-p/5008212/highlight/true#M...
Report it via subscription or on the Autodesk "Contact Us" page:
The more people that report the problem, the more likely Autodesk will issue a fix.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
in reply to: joe
if you type your inch (") mark after each fraction they should stack
joe
Hi kentr8,
That can be done, but is not the way structural steel angles are shown. I can sack the fractions, and delete the spaces but that is like going backwards or back to pencils and t squares:)
christina.davis
in reply to: joe
Hi Joe,
I'm able to reproduce this behavior, but at this time I can only suggest the workaround that you have found: highlight the fraction, right-click and choose Stack (or click the Stack icon on the Formatting ribbon panel).
In the 2015 release some changes were made to auto-stacking, and the program is looking for a space to be entered right after the "bottom" number, in order to stack and remove the leading blank. Seeing the X entered after is blocking it from auto-stacking.
I appreciate that this will require extra clicks, and is not a final solution. However, we are aware of the issue, and hopefully this will get you by until it can be fully resolved.
Please hit the Accept as Solution button if my post resolves your issue.
Christina Davis
Technical Support Specialist
Frontline Technical Support
Autodesk, Inc.
tommy
in reply to: christina.davis
This is a major issue and my Detailers will not upgrade to the latest versions (2015 or 2016) of Autocad because of this. Well I guess we dont need that subscription license anymore........
joe
in reply to: tommy
Really not a big deal once you deal with it for a time. It becomes
second nature. Maybe they will fix it
sometime.
Joe
Sent from my iPhone
”Boost
