I have a 3D model made of Alumn, Steel, Glass and MDF...
When using the layout command and creating cross sections from my model, is there a way to assign a hatch to a material (or layer) so when I creat a cross section, the hatch patterens are assigned based on the layer they are on, or the matterial that is assigned to that layer?
At the moment, all layers and materials are using the same hatch. I don't want to go through my entire drawing package and moidify each individual hatch.
Help...
Please....
-Ben
The only way I can think of doing it would be to use different section styles if you are using the section cut command or maybe a macro that would go in and do it for areas you selected.
