AutoCAD 2013/2014/2015
LisaDrago
Message 1 of 5 (1,808 Views)
Attribute text not displaying
1808 Views, 4 Replies
12-27-2012 03:15 PM
Hello - I have a client with an issue I cannot figure out...
They have one file xrefed into another but the text is not showing up. It is a block and the text is an attribute - but it is exploded.
I have attached 2 images - the first one - of the original file the second - where it is xrefed into another file with the text missing.
Any thoughts??
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
grimline
Message 2 of 5 (1,794 Views)
Re: Attribute text not displaying
12-27-2012 07:56 PM in reply to: LisaDrago
What if they "BURST" instead of exploding the attribute?
Autodesk AutoCAD Map 3D 2015
Windows 7 Professional
Service Pack 1
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
Alfred.NESWADBA
Message 3 of 5 (1,777 Views)
12-27-2012 10:44 PM in reply to: LisaDrago
That might be the source of the problem as some people try to use attribute-definitions to place text within a drawing. The bad thing is that it works, they can start ATTDEF, and write the text .... but this written text is then the name of the attribute-definition.
As long as you leave the object like it is it looks like a text-info, but (and now the bad way starts) don't use this drawing with that attribute-definitions within any other drawing. In case of e.g. _INSERT this drawing into anohter one the attribute-definitions are part of the inserted block, but then they show up the values of the attribute ==> and the values are empty, the name of the attribute is not any more written down like a text. (hope that is clear described).
Either you have a tool that converts attribute-definitions to text-objects or you don't insert this drawing into any other one .... or you tell the guy who used attribute-definitions instead of text that he/she has to repair that.
HTH, - alfred -
Alfred NESWADBA
KateMorrical
Message 4 of 5 (1,765 Views)
12-28-2012 09:29 AM in reply to: LisaDrago
Attribute definitions (outside of blocks) don't show up when their host file is xrefed. They have to be part of a block definition to be visible.
A fix I saw suggested on another forum is to make a temporary block from the attributes and then use BURST to convert them to text.
Kate Morrical
Digital Design Manager
Washington, DC
BIMmuse.com
LisaDrago
Message 5 of 5 (1,757 Views)
12-28-2012 09:38 AM in reply to: KateMorrical
I had trued just the burst and that did not work - creating a tempoary block and bursting that worked.
Thank you all for your help!
LD
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
