AutoCAD Forum
Assign UCS to viewport
0 REPLIES 0
Message 1 of 1
Predator_mpm
297 Views, 0 Replies
I have checked thepost here:
http://adndevblog.typepad.com/autocad/2012/07/restore-previously-saved-ucs-using-objectarx.html
You will find a note below: This solution does not change the UCS name that is displayed by AutoCAD using the UCSNAME system variable.
Is there a solution that does the same but shows the ucs name when using the ucsname variable?
Tags (2)
0 REPLIES 0
”Boost
