Hi all,
Attaching the draw.
The top transom (beam) has to be cut on 2 levels degree : in\out as the circle diameter , and up and down as the slope .
I made the drawing with the SWEEP command of a 2D transom view along a line, but the result is not good To get the dimensions of manufacturing, it is good as a general "simulation".
How can i do it more accurate?, or it is a big task for the autocad?
Thank you all.
yaron.
Solved by nestly2. Go to Solution.
Assuming the obects are aligned properly, you can use SLICE to trim the object to the face of the vertical members by using the 3Point option, or realigning the UCS. It's difficult to know exactly how to describe how to do this without knowing how the corners are supposed to be formed.
