Hi All.
We have an increasing need to fully adopt client requirements of adding annotative scale to blocks. An example of the extent is, in 1 drawing we have 4000 blocks (about 10 variations) all with 3-5 annotative scales.
File size has increased from 3mb to 6mb, and the save time has increased from 10seconds to 5 minutes.
Otherwise the drawing is clean, the blocks are clean, its just when annotative objects are replicated a number of times.
Any ideas of potential solutions would be appreciated.
Solved by Alfred.NESWADBA. Go to Solution.
welcome @forums.autodesk.com!
That the filesize increases is normal, but the save time should not increase from 10sec to 5min.
So:
HTH, - alfred -
Hi Alfred
Absolute Champion!
Savefidelity did the trick.
Thank you so much.
