AutoCAD Forum
Animation preview
7 REPLIES 7
Message 1 of 8
425 Views, 7 Replies
Animation preview
Animation preview was working, now only shows camera along path. Would like to see the preview. Is this a setting I am overlooking?
7 REPLIES 7
Message 2 of 8
Mistress0fTheDorkness
It's been awhile since I've used this tool, but, I'm curious if you graphics card is one of the 'autodesk approved' ones?
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
(the MURL is: www.autodesk.com/graphics-hardware-detail )
If it was previously working for you, do you know if your graphics card driver has been updated since then, so that perhaps rolling back to an older driver could resolve it?
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
Message 3 of 8
in reply to: Mistress0fTheDorkness
It was working yesterday right before I tried to pull a drawing off another drive and got a windows blue screen.
After that it will not come up. So must have had something to do with windows crashing. Rolled back
windows and set acad back to defaults still no luck....lost all of my customization also. Not a good day.
Message 4 of 8
edwin.prakoso
All I know, the setting that can enable/disable preview window is this. Have you turn it on?
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
Message 5 of 8
in reply to: edwin.prakoso
Yes, it is turned on.
Message 6 of 8
Steve_Bessette
Is it occuring with all files or only one?  If only one, could you provide the file?  If all files, I would try to log on as a different Windows User.  The other alternative would be to perform a clean uninstall of AutoCAD and test (http://knowledge.autodesk.com/article/How-to-perform-a-clean-uninstall-of-an-Autodesk-product)
Steve Bessette
Support Specialist
Product Support
Message 7 of 8
in reply to: Steve_Bessette
sorry, can't provide the file,,,have to put in ticket to corporate to do a repair...
Message 8 of 8
yes system is autodesk certified
”Boost
