My current text style using Aerial Narrow. I have mtext that has the Angle symbol in it. The text looks fine until I create a PDF file. After i plot to the PDF file the Angle symbols become squares.
Does anyone know what the problem is? Any help would be great
Using Autocad 2014
In your PDF driver (or PC3 file) there are settings for font handling which may be the cause. These will differ depending on which PDF driver you are using. For example, AutoCAD's DWG to PDF driver has a Custom Properties page:
Experiment with different settings there.
Also search previous posts for "PDF capture all fonts". One example:
Thanks for the input. Aerial Narrow was check off already. I then selected Capture All and I checked As Geomtry. Saved the PC3 and then tried again. It still did not work. I also restarted autocad.
I'm in the middle of changing the font for the symbol to Simplex and that seems to work.
Why would anyone not want to capture all?. Its one of those setting that makes me wonder why?
"...changing the font for the symbol to Simplex and that seems to work."
From some of the posts I saw it seemed that switching to a different font often was the (only?) solution.
"Why would anyone not want to capture all?"
That's a good question which I have wondered about as well. I assume it impacts file size, and maybe it is configurable to give control over the ability to search within the PDF file (or not). Not sure...perhaps some PDF guru out there will enlighten us.
