I have this situation hard to handle. On the Advanced Render Settings menu the Output file size option is gone.. sometimes it comes back when i close then open Autocad..
It looks like a common unresolved bug has i can see on google but with now resolution yet.
Is there a keyboard short cut to open the Output Size box has on the picture bellow, i can't see anything inside the command line either inside Autocad help.
A keyboard shortcut could correct the situation. (This picture is comming out of a fresh DWG of course)
Tx.
ok..
it's at 2000 x 2000 now so is more then enough to get my final result, fortunatley.
But i would not be a luxuary to put it back at 800 x 600 to get a faster result. Ill wait then.
I am having same problem cannot find this dialog box on my AutoCAD, can you pls help me. AutoCAD 2017 Windows10
Rgs
is it that list you are looking for?
- alfred -
Hi @Peac3,
If you change from Presentation to somtething different, does the output size reappear? Also, Does the Render to Size drop-down help to get it back?
Hi @Peac3,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
Hi @Peac3,
Thanks for letting me know.
Have a good one!
