AutoCAD Forum
Adding Superscript text in AutoCAD 2014 and 2015
2 REPLIES 2
douglas
17241 Views, 2 Replies
The attached pdf's are from the powerpoint lecture slides included with the textbook Technical Drawing 101 with AutoCAD 2015 by Smith, Ramirez, and Schmidt.
Douglas W. Smith, M.A. | Department Chair
Architectural and Engineering Computer Aided Design
Austin Community College | Northridge Campus
11928 Stonehollow Drive
Austin, TX 78758
2 REPLIES 2
riseball
in reply to: douglas
TIP, I used to add a separate piece of text, or floating attribute for things like METERS SQUARED. Using MTEXT it's easy...
METERS SQUARED (m^2) SUPERSCRIPT WITH MTEXT
Create a stacked fraction (TYPE 3/4), it will automatically stack is with smaller text, hightlight it, the RIGHTCLICK, STACK PROPERTIES.
Change the STYLE to TOLERANCE, and UPPER TEXT TO (2) and LOWER TEXT (leave blank) this will give you and actual meters squared as one object.
pendean
”Boost
