I'm running AutoCAD 2013 and need to know how to add section callouts to plans using the Sheet Set Manager. The image below is from the supplied sample project IRD Addition Sheet set Manager. Adding callouts were so much easier using AutoCAD Architecture, but that's no longer an option.
Solved by Jason.Piercey. Go to Solution.
To specify which blocks are to be used:
Open the sheet set > Right click on the heading/title > Under Sheet Set you'll find Callout blocks > Browse for the block you want to use.
To place a callout block on the drawing:
Set the Sheet View tab active > Right click on a view > Place Callout Block > Pick what block you want to place.
