I can't see my Add delete Scales window or when I need to edit a block I can't see my window. So I can't see most of the windows used for edit things.
Does anyone know about how to fix this issue. I'm using AutoCAD 2014.
J
When I have a problem I turn off AutoCad and go to Control Panel, Programs & features and select AutoCad14 to 'uninstall or change'. Click on that and AutoCad's Repair window opens. Select Repair.....Finish. And you're done. Hope this works. LL
